查看: 924|回复: 1
想做物体或者人脸识别,安装usb-cam运行后报错,查看实时图像时显示不出usb-cam的图像
注册会员
发表于 2025-2-26 10:46:48 | 显示全部楼层 |阅读模式
安装了usb-cam,但是运行roslaunch robot_vision usb_cam.launch 后报错
[ INFO] [1740536955.740403271]: using default calibration URL
[ INFO] [1740536955.741620887]: camera calibration URL: file:///home/hawkbot/.ros/camera_info/head_camera.yaml
[ INFO] [1740536955.741807514]: Unable to open camera calibration file [/home/hawkbot/.ros/camera_info/head_camera.yaml]
[ WARN] [1740536955.741835188]: Camera calibration file /home/hawkbot/.ros/camera_info/head_camera.yaml not found.
[ INFO] [1740536955.741860610]: Starting 'head_camera' (/dev/video0) at 640x480 via mmap (yuyv) at 30 FPS
[ERROR] [1740536955.741987453]: Cannot identify '/dev/video0': 2, No such file or directory
[usb_cam-1] process has died [pid 6827, exit code 1, cmd /opt/ros/noetic/lib/usb_cam/usb_cam_node __name:=usb_cam __log:=/home/hawkbot/.ros/log/52c00708-f3e9-11ef-ba4e-c589a1116ef5/usb_cam-1.log].
log file: /home/hawkbot/.ros/log/52c00708-f3e9-11ef-ba4e-c589a1116ef5/usb_cam-1*.log
发表于 2025-2-27 11:04:49 | 显示全部楼层
最新的小车默认就自带相机,会发布相应话题,如果是老的使用树莓派的小车,请先检查树莓派是否识别到了usb相机,然后检查/dev/video0是否存在
GMT+8, 2026-10-26 14:36 , Processed in 0.019913 second(s), 17 queries .
